After the April upgrade my Vero4k has video play back issues. The brightness of videos is dim and SD video quality is terrible. It was fine prior to the upgrade.
I was using Titanium skin which is no longer compatible so changed to Aeon Tajo, which I really like and it displays fine. It is just video playback that is an issue.
Dark scenes on SD video are so more blotchy. Is there a way to fix this?
If not is there a way to roll back the upgrade?
reboot the OSMC device
reproduce the issue
upload the log set either using the
I think the issue was skin related. I changed to Amber and the playback is much better.
I did not think that the skin I use would affect video playback but that seems to be the case. Pity as I liked Aeon Tajo but happy to use Amber instead.
Is this a known issue?
No.
