I have a Vero4K+ on my main floor, and a rPi 3B in my basement both running latest OSMC version 2019.11-1. I’ve noticed recently that when I try to play back m2ts Home Videos from my Full HD AVC Sony Handycam that the playback is too quick. It wasn’t always this way - it used to play fine probably a month or so ago.
I held off on updating my 4K+ from kodi 17 to 18 until about that same time frame. However I kept my rPi OSMC install up to date with v18 releases. The same m2ts playback on the rPi instance is perfectly fine. I am using a combination of uPnP connection to my NAS as well as SMB mounts - both are problematic on the 4K+ only.
Yesterday on my 4K+ I stopped OSMC, moved .kodi directory to .kodiorig and started OSMC fresh again. Rebuilt the uPnP and SMB connections and the issue continues to persist. I also played around with disabling/enabling the hardware acceleration of video files - turning it off on 4K+ resulted in extremely slow playback - unusable.
The rPi hardware acceleration is different to the 4K+ - MMAL vs Amcodec (or something like that).
Please let me know how to get the best logs output for diagnosis.
Cheers,
Ed.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Hopefully the issue is now addressed.
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
Looks like that did the trick Sam, eureka!
Can I ask what it was? A regression perhaps?
It’s a problem with refresh rate switching. It will be fixed in the form of an official release shortly. Thanks for confirming.
