My LAN internet works good, however after stopping the (movie) player I have noticed in the info section that my MAC address and Internet is showing as ‘Busy’. This prevents me from playing directly another movie or TV show as the wheel keeps spinning. After a minute or so the status is changed from Busy to actual showing the MAC address and Internet to connected.
My internet is connected directly to the router with speeds up to 200.
See below, also if it is a Pi4 suggest to stay in the testing thread.
reproduce the issue
From an underlying OS point of view the Wireless connection is not lost after the connection at 11:09.
So not sure why Kodi displays that issue. Is that shown in the Settings → System Info → Network dialog?
That sounds high for a Pi4. Might a coming from an addon.
No only by disabling them 1 by 1.
But Artctic Horizon could be eating some CPU, but not sure how much.
Could your network problem be related to power issues? Do you have proper power supply?
Showing Busy is normal behaviour in Kodi on first entry. It is not specific to OSMC. From my experience if you exit the screen, wait a couple of secs and go back in to the info screen it should show correctly.
Thanks for the support. Will disable the addons 1 by 1.
Regarding power supply… I have the official pi power adapter.
I have noticed that my 5GHZ Wifi is limited to 50mbps when checking speedtest. All my other devices are showing the max of 200mbps. Not sure why Pi4 is limited. Could this cause the issue?
Well I always suggest to test speed with iperf3 between LAN devices.
Anyway that speed could be close to what you can achieve. You can install sudo apt-get install wavemon to check the wifi speed negotiated
