Macos samba client crashes OSMC smbd
Connecting to sub-directory on USB disk from Macos fails.
Been happening for a while, complete new build of OSMC, no difference.
Fine from Win10 laptop.
Code:
smbd.service - Samba SMB Daemon Loaded: loaded (/lib/systemd/system/smbd.service; disabled; vendor preset: enabled) Drop-In: /usr/lib/systemd/system/smbd.service.d └─smb-app-osmc.conf Active: active (running) since Tue 2024-07-23 11:29:14 ACST; 1h 41min ago Docs: man:smbd(8) man:samba(7) man:smb.conf(5) Process: 608 ExecStartPre=/usr/share/samba/update-apparmor-samba-profile (code=exited, status=0/SUCCESS) Main PID: 609 (smbd) Status: "smbd: ready to serve connections…" Tasks: 4 (limit: 3931) CPU: 2.719s CGroup: /system.slice/smbd.service ├─609 /usr/sbin/smbd --foreground --no-process-group ├─611 /usr/sbin/smbd --foreground --no-process-group ├─612 /usr/sbin/smbd --foreground --no-process-group └─660 /usr/sbin/smbd --foreground --no-process-group Jul 23 13:08:54 osmc smbd[853]: If you are running a recent Samba version, and if you think this problem is not yet f> Jul 23 13:08:54 osmc smbd[853]: [2024/07/23 13:08:54.150181, 0] …/…/lib/util/fault.c:169(smb_panic_log) Jul 23 13:08:54 osmc smbd[853]: =============================================================== Jul 23 13:08:54 osmc smbd[853]: [2024/07/23 13:08:54.150277, 0] …/…/lib/util/fault.c:170(smb_panic_log) Jul 23 13:08:54 osmc smbd[853]: PANIC (pid 853): Signal 11: Segmentation fault in 4.13.13-Debian Jul 23 13:08:54 osmc smbd[853]: [2024/07/23 13:08:54.150619, 0] …/…/lib/util/fault.c:274(log_stack_trace) Jul 23 13:08:54 osmc smbd[853]: BACKTRACE: 0 stack frames: Jul 23 13:08:54 osmc smbd[853]: [2024/07/23 13:08:54.150837, 0] …/…/source3/lib/dumpcore.c:315(dump_core) Jul 23 13:08:54 osmc smbd[853]: dumping core in /var/log/samba/cores/smbd Jul 23 13:08:54 osmc smbd[853]:
Hope you guys can help.
Thanks,
Luke
Since OSMC is shipping smb v 4.13.x something, there is a known issue with Mac clients in Debian. I believe Debian was as usual “a bit behind” for stability, I’ve not checked which version is in next Debian upgrade for OSMC. The smb-package 4.13.x from Ubuntu didn’t have exact same issue but there something mentioning multi channel support, and Mac’s rebooting with mounted shares, triggering a segfault in smbd. Since I’m have no access to any box running Apple, I can’t really verify or test any possible changes right now.
Thanks for your informative reply joakim_s. At least I know where to look. Cheers.
I don’t have a Mac but if SMB Multichannel is to blame, you can disable it on the Mac or file server.
For Mac: Configure SMB Multichannel behavior - Apple Support
short version: add the following line to the /etc/nsmb.conf file:
mc_on=no
For Linux or NAS (If not available in the GUI):
add or edit the line to /etc/samba/smb.conf
server multi channel support = no
I’ve never came across SMB Multichannel until last week when I had to troubleshoot and discus it on two occasions. Turns out it has 0 benefit unless both your server and client are connected with multiple network connections to each other.
I’ve noticed several NAS manufacturers are using this option to provide a cool screenshot of their NAS delivering 5 Gbps disk speeds but i doubt many people have 4 cables between their NAS and client to come close to this higher level enterprise setup or lab setup.
Hi nAFutro, Thank you for the effort to respond and your insight.
Unfortunately your suggestions did not resolve my problem.
I think Apple have broken Samba and do not care to fix it.
I am actively seeking other solutions
Thanks again.
