I’m having some trouble mapping to an NFS share on my QNAP using my Raspberry Pi 4B with OSMC. I had no problem accessing the same file share with the same credentials on my old Raspberry Pi 3 with OSMC.
/etc/auto.nfs.shares
Content (pay attention to the colon):
/mnt/192.168.74.96/nfs 192.168.74.96:/nfs
sudo reboot your rpi to get the nfs share mounted
Since the user osmc will not be a real user on your QNAP, you should also pay attention whether the right squash option is set on your NAS: Mounting NFS - QNAPedia. You say you don’t have any issues accessing the NFS share using your rpi 3, so there there might nothing to do here.
If this is all done, you can use the Root Filesystem method to specifiy the access to the data on the NFS share. Use the path /mnt/192.168.74.96/nfs accordingly.
Thank you in advance, not sure what I have missed?
I double-checked the QNAP NFS host access permissions. It is set to allow all IPs on 192.168.74.0/24 (all IPs on my home network).
The squash option was set to “squash no users”, which works with my old RPi3. I did try flipping that setting to “squash all users” as the referred kb recommended but that didn’t make a difference.
just to be sure: You have 2 lines in file /etc/auto.master and 1 line in file /etc/auto.nfs.shares?
Or did you just write that all into /etc/auto.master ?
Thank you very much for all of your help. I got the shares working with your instructions. I just missed the part of adding the files to the GUI in OSMC so I could access them.
