Hi all,
I’m trying to run a python3 script which makes use of matplotlib on my raspberry pi2 running OSMC.
Matplotlib python package wasn’t installed, hence I ran the following command:
pip3 install matplotlib
which returned the following error:
Collecting matplotlib
Using cached https://files.pythonhosted.org/packages/89/0c/653aec68e9cfb775c4fbae8f71011206e5e7fe4d60fcf01ea1a9d3bc957f/matplotlib-3.0.2.tar.gz
Collecting numpy>=1.10.0 (from matplotlib)
Exception:
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 391, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 387, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.5/http/client.py”, line 1198, in getresponse
response.begin()
File “/usr/lib/python3.5/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.5/http/client.py”, line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/lib/python3.5/socket.py”, line 576, in readinto
return self._sock.recv_into(b)
File “/usr/lib/python3.5/ssl.py”, line 937, in recv_into
return self.read(nbytes, buffer)
File “/usr/lib/python3.5/ssl.py”, line 799, in read
return self._sslobj.read(len, buffer)
File “/usr/lib/python3.5/ssl.py”, line 583, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed outDuring handling of the above exception, another exception occurred:
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 393, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 313, in _raise_timeout
raise ReadTimeoutError(self, url, “Read timed out. (read timeout=%s)” % timeout_value)
requests.packages.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host=‘pypi.org’, port=443): Read timed out. (read timeout=15)During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 630, in send
history = [resp for resp in gen] if allow_redirects else
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 190, in resolve_redirects
**adapter_kwargs
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’
Anyone knows what’s going on here ?
Thanks ahead for your help
