MCE Keyboard
Anyone might know how to make IR MCE Keyboard work on Vero 4K.
Thank you in advance
MyOSMC add-on>remotes?
They should work out of the box: enabling the RC6 decoder is probably sufficient.
I have assigned rc6-mce-lircd over MyOSMC->remotes and harmony hub does work as standard remote as “Microsoft Media Player”, but when I do assign keyboard keystroke as “Microsoft MCE Keyboard” then the Vero does not react to it, but if I press the same button on the real keyboard it does work, just not over IR.
Which remote should I set to get Microsoft MCE Keyboard funtionality.
And yes, I have enabled RC6 decoding.
Some Harmony owners might have better knowledge. There’s been quite a lot of discussion about using Harmony with Vero 4K.
Yet another post for me to tag you in @Smurphy.
Thank you @sam_nazarko, but believe me that before I have posted this question, I have done all those discussions over and over, spent a week on that.
I do not have a problem that remote would not work at all.
It does work as it should as “Microsoft Media Player” IR profile with limitations that “Microsoft Media Player” has.
I need to extend functionality with sending keyboard keystrokes over the IR like “Microsoft MCE Keyboard”.
Since my question is not IR not working at all, but extending functionality I have opened a new topic. But I can go to other discussions to ask again there.
My first Kodi box is/was Intel NUC where I have no problem setting that.
Now I have ported all my stuff from NUC to Vero, and this is 1 of 2 problems I need to resolve yet.
Thank you and cheers
p.s. I am sure that you could be helpfull with my 2nd question, but in another topic about that
@sam_nazarko thank you for pointing me out to @Smurphy.
I have reread those topics, now more through, and I have now working remote over BT mimics as Windows Computer and OSMC as remote.
Glad to hear this. Will keep an eye out for your second question
