During the past week or two, when I or a member of the family has come to use the Vero, after switching to the appropriate HDMI input we find the familiar OSMC interface unresponsive, with the clock showing a time in the past, as though it has frozen at a point in time. This time varies from one instance to another, so it’s not consistent to a particular time of day.
Troubleshooting & Workaround
The Vero box itself appears to still be “up” as Yatse is able to connect and I can still issue commands via SSH. Issuing a Reboot power action via Yatse does nothing, however sending a sudo reboot now via SSH would successfully reboot the OS and bring everything back to life. Following the most recent instance this morning, I found that simply issuing a sudo systemctl restart mediacenter via SSH avoided the need for a full reboot and brought the interface back to a responsive state.
Version & Device Information
osmc@vero-4k:~$ grep Kodi .kodi/temp/kodi.log | head -3
2022-03-21 08:12:12.488 T:7867 INFO <general>: Starting Kodi (19.1). Platform: Linux ARM 32-bit
2022-03-21 08:12:12.488 T:7867 INFO <general>: Using Release Kodi x32 build (version for Vero)
2022-03-21 08:12:12.488 T:7867 INFO <general>: Kodi compiled 2021-08-03 by GCC 8.3.0 for Linux ARM 32-bit version 4.19.152 (267160)
osmc@vero-4k:~$ grep VERSION_ID /etc/os-release
VERSION_ID="2021.08-1"
Timescale / Peripherals
I’m not certain when this first occurred, as I thought it was a one-off and didn’t make a note a of it, but it was certainly within the past month. It most recently occurred this morning at 8:09 with the above command issued at 8:11.
Only the receiver for the OSMC remote is attached, and no new peripherals have been added since it was purchased.
Logs
osmc@vero-4k:~$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/boletekaju
This is an old version, first recommendation is to update to the latest OSMC Version.
Check via MyOSMC - Manual Update if no update is provided please let us know.
Or via SSH sudo apt updatesudo apt dist-upgrade
2022-03-21 10:50:01.691 T:11874 INFO <general>: Starting Kodi (19.4). Platform: Linux ARM 32-bit
2022-03-21 10:50:01.691 T:11874 INFO <general>: Using Release Kodi x32 build (version for Vero)
2022-03-21 10:50:01.691 T:11874 INFO <general>: Kodi compiled 2022-03-08 by GCC 8.3.0 for Linux ARM 32-bit version 4.19.152 (267160)
VERSION_ID="2022.03-1"
Ok we’re up to date now, I guess I’ll see how it goes. Thanks for pointing out something I should have spotted!
Unfortunately it has happened again. Oddly, it seemed to freeze at the moment I switched HDMI inputs, as the time was initially correct when it became unresponsive (17:40) and stayed that way until I restarted the media center service.
2022-04-12 17:40:30.772 T:2736 INFO <general>: Toggle standby state is waking
2022-04-12 17:40:30.772 T:2736 INFO <general>: CApplication::ToggleStandby -- Toggle TMDS clock to 1
2022-04-12 17:40:30.822 T:2736 INFO <general>: CApplication::ToggleStandby -- Toggle LED brightness to 1
2022-04-12 17:40:30.822 T:2736 INFO <general>: CApplication::ToggleStandby -- governor will now be ondemand
2022-04-12 17:40:30.822 T:2736 INFO <general>: CApplication::ToggleStandby -- HPD locking will now be hpd_lock0
2022-04-12 17:40:30.823 T:2736 INFO <general>: CApplication::ToggleStandby -- checking for existence of /home/osmc/.kodi/userdata/wake.py
2022-04-12 17:40:30.824 T:2618 INFO <general>: ToggleDeviceState - activating CEC device
2022-04-12 17:40:36.028 T:2618 ERROR <general>: CPythonInvoker(181, /home/osmc/.kodi/addons/screensaver.picture.slideshow/default.py): script didn't stop in 5 seconds - let's kill it
I’m beginning to suspect the slideshow screensaver. I’m going to disable it and see if that helps.
Hey Sam. Yes it is, the same Synology NAS that houses the source media files for both Movies & TV. I think you’re probably right, I didn’t make the connection between switching to a slideshow and this issue starting, but it may have been around the same time.
