Typical issue I am experiencing is as follows: I use my Vero 4k+ to watch an episode of TV in the evening. When done I often hit stop and then turn off my TV. When I return the next evening I usually turn on the TV then hit a button the Vero 4k+ remote to wake the device. However, very often the OSMC/Kodi mediacenter app is frozen and/or does not respond to any remote control presses. I am pretty sure it is frozen because the clock in the Kodi app seems to usually show a time around when I woke the machine – so it seems the Kodi app is freezing at that time.
To resolve this I either remove the power cable and/or SSH into the box and run systemctl restart mediacenter. The box is obviously not completely frozen as I can SSH and run commands and all is fine after restarting the app.
Anyone else having an issue like this? Any way I can diagnose what the issue is and/or how to fix?
Is there an argument to be made that this issue should really be fixed in Kodi? Should Kodi allow itself to freeze up from an add-on that has a bug – or should Kodi be able to isolate/disable the misbehaving addon/script and continue as normal?
