I’m using OSMC on a RPi 3B+. I’ve been running 2022-03 for months without issues.
I updated to 2022-09 on 03 Oct. The update went smooth and everything felt OK until today, 17 Oct. The system was unresponsive; I found out that the kodi process held 67% of the main memory. It was impossible to stop the kodi process, so I had to re-power the system.
I have a log of available memory over time, here an excerpt:
750 MB 07/Oct on boot
550 MB 07/Oct Kodi started & idle
520 MB 08/Oct
420 MB 09/Oct
380 MB 10/Oct
370 MB 11/Oct
300 MB 12/Oct
260 MB 13/Oct
220 MB 14/Oct
180 MB 15/Oct
140 MB 16/Oct
100 MB 17/Oct
Roughly speaking, this is 40MB per day. Kodi is mainly used as PVR client (live & recordings). I have a kodi.log of the time range but didn’t find anything useful in it.
This may be an upstream issue, I didn’t research yet, just want to report it here to be able to track it.
reproduce the issue
Do you mind I share the log with the other moderators on this discourse?
I’m fine with that when access to the logs is limited to moderators and/or maintainers.
Thanks for your idea to try a clean kodi profile. I will check it out and post the results here, it may take some time.
My uneducated guess so far: Since memory usage increases even when the system is idle, and the only activity logged in this time is the deletion of worker threads, the behavior may be caused by spawning short-lived threads, could the introduced by the kernel switch with bullseye. I have no evidence for that, the log messages could be completely unrelated, though.
Is the Kodi 19.4 in 2022-09 the same as the Kodi 19.4 in 2022-03?
Running kodi with a vanilla profile for one night led to constant memory usage, no increase any more. Looks like the leak is caused by something in my profile. That’s great news because it indicates that the problem does not arise from the core of kodi or osmc. In the next step I will try to find out if the leak is caused by a plugin or something else.
