hi guys!
Just wanted to report a weird glitch, I have these texts coming on my screen when OSMC is booting on a rpi2:
log file:
http://paste.osmc.io/raduvejoku
Any workaround to hide this?
Thank you in advance.
hi guys!
log file:
Hello
Did you edit /etc/rc.local?
Did you install any new packages?
systemd will start displaying output if a unit takes a long time to start. I suspect you have added something to rc.local which should really be a systemd unit
hi Sam!
I think it might be related to this: Auto ext4 usb mount - how? - #17 by a1840317
You helped me a few weeks ago, coz i had issues with the auto mounting of the attached usb pendrive.
Does commenting that line out fix it? Do you have any additional packages installed?
I am mobile so haven’t been able to review your logs yet.
Thank you Sam, i think commenting out that line solved the issue.
Right now even the usb pendrive is connected, so does it mean that bug was fixed in osmc itself, so i don’t need to worry about this custom mounting anymore?
If it’s still working then leave it out. Let me know if things take a turn for the worse.
Thanks Sam!
