Yes, you were correct, I was mixing up event log and debugging log.
I did set it into debugging mode this time ( lots of info going on in the top Left corner)
It’s a bit of a pain to set up as my hard drive is normally connected to my pc.
When I reconnected and switched it on, it scrapped info for Breaking Bad season 1. (So havn’t uploaded a debugging log as yet). I had previously been playing with these file and folder names to see If I could get a match.
But I hadn’t changed anything from my previous attempt.
Guessing I was refreshing the file scan from the wrong place. Managed to get another match to season 2, by just adding the year to the season folder, rather than each file. And then refreshing from the media set up folder(via settings), rather than the front end one you use for viewing? ( Does that make sense?)
This little device does seem really great at playing all the files I’ve been trying out, but I’m finding Kodi really un-intuitive?
Even the guides seem to be a bit long winded at time, any suggestions for a newbie?
I don’t even find the menu structure easy to navigate, I keep going the wrong way.
I’m not having a go, but being a previous user of Plex , I could figure most thing out by just giving it go…
For example: I was trying to correct a bad match on my Movie database due to a featurette extra.
I wanted to find out the actual file Kodi was looking at, you have to press info on the movie, then scroll across one more click to “refresh” rather than scroll across to “more information”
So easy when you know, but just really annoying when you don’t, think that’s why I ended up her in the first place.
Anyway thanks for your help, sorry it taking me a while to get back to you.( I’m hesitant to bang my head against the wall again)
Warm Regards
Phil
