Migration from Vero 4K to Vero 5
Did you do mkdir /mnt/AVOIR?
now yess (sorry for my very low skills )
osmc@osmcvero5:~$ mount -t cifs -o username=XXX,password=yyy,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/avoir /mnt/avoir
mount.cifs: permission denied: no match for /mnt/avoir found in /etc/fstab
Apologies need to put sudo infront so sudo mount -t cifs -o username=XXX,password=yyy,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/avoir /mnt/avoir
But I really do not understand why you are using lower cap avoir where I clearly have said to use captial case AVOIR.
osmc@osmcvero5:~$ sudo mount -t cifs -o username=XXX,password=ZZZ,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/avoir /mnt/avoir
mount error: Server abruptly closed the connection.
This can happen if the server does not support the SMB version you are trying to use.
The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
mount error(112): Host is down
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
osmc@osmcvero5:~$ ping 192.168.1.50
PING 192.168.1.50 (192.168.1.50): 56 data bytes
64 bytes from 192.168.1.50: seq=0 ttl=128 time=1.150 ms
64 bytes from 192.168.1.50: seq=1 ttl=128 time=0.873 ms
64 bytes from 192.168.1.50: seq=2 ttl=128 time=0.877 ms
64 bytes from 192.168.1.50: seq=3 ttl=128 time=0.923 ms
^C
— 192.168.1.50 ping statistics —
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.873/0.955/1.150 ms
and in same time i did a nmap :
osmc@osmcvero5:~$ nmap --script smb-protocols 192.168.1.50
Starting Nmap 7.80 ( https://nmap.org ) at 2025-04-17 18:07 CEST
Nmap scan report for ordi-salon.home (192.168.1.50)
Host is up (0.79s latency).
Not shown: 994 closed ports
PORT STATE SERVICE
22/tcp open ssh
135/tcp open msrpc
139/tcp open netbios-ssn
445/tcp open microsoft-ds
1236/tcp filtered bvcontrol
5357/tcp open wsdapi
Host script results:
| smb-protocols:
| dialects:
| 2.02
| 2.10
| 3.00
| 3.02
|_ 3.11
Nmap done: 1 IP address (1 host up) scanned in 9.10 seconds
osmc@osmcvero5:~$
While I find this strange especially if you haven’t changed anything on your Windows machine, you can try with vers=1.0 but not sure if it makes a difference.
sudo mount -t cifs -o vers=1.0,username=XXX,password=ZZZ,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/avoir /mnt/avoir
While I am still confused about your ignorance of the uper case of your share name (while it might not make a difference it surely doesn’t harm to follow
osmc@osmcvero5:~$ sudo mount -t cifs -o vers=1.0,username=xxx,password=zzz,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/avoir /mnt/avoir
Sorry I am out of ideas. Surely something wrong.
I have tryed with other vero4K i have with no update (it’s a release 2024) and the is no latency… I belevied it’s occur when i update on march 2025 release (i have several Vero 4K and one Vero 5).
I have this problem on all 2025 release and NOT with 2024 one…
Does
mkdir /mnt/AVOIR
mount -t cifs -o username=your_username,password=your_password,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/AVOIR /mnt/AVOIR
ls -lah /mnt/AVOIR
work on that device?
Hello, i have (same after disabling all firewall) :
osmc@osmc:~$ sudo mount -t cifs -o username=YYY,password=XXX,iocharset=utf8,uid=osmc,gid=osmc //192.168.1.50/AVOIR /mnt/AVOIR
osmc@osmc:~$
Ok, while this is still super strange and might still also be source of your issue let’s focus why the old version might work while the new one doesn’t. Suggest to provide debug enabled logs from the working and not working system.
