I’ve just migrated from a Vero 4K+ to a Vero V and I’ve noticed that audio is only PCM. I went into Settings > System > Audio to enable passthrough, but I can’t see the passthrough options. I’ve tried a different HDMI input on the Amp, and a different HDMI lead.
Connectivity is: Vero V > Onkyo Amp > Samsung UHD TV
This was working before on the Vero 4K+
I suspect I’m doing something really silly, so apologies in advance if it is!
Switch your skin to Estuary temporarily and see if it shows up there. Is this a manual clean setup or did you import your settings from a backup. I’m scratching my head a bit on this one as I can’t think of a reason why that setting isn’t showing up.
Thanks, I’ve managed to fix it. Estuary had the same issue, however I tried the “Reset above settings to default” and the options returned (and are still visible now I’ve returned to the original skin).
I did a full settings restore from the Vero 4K+ (except thumbnails) on the Vero V.
I see the passthrough options include the passthrough device… I wonder if the old Vero 4K+ output device is in the configuration file that is imported, but because the hardware doesn’t exist that section errors out?
I checked my other Vero - which has just gone from Vero 4K to V (same migration process). That looks ok, although it doesn’t use Passthrough, so maybe that section of the config isn’t stored/imported.
I don’t think that device selection should make a difference here. There might be a clue if you ran a diff between the guisettings.xml from the Vero 4K and the one currently working on the Vero V if your really curious. Nice find on the solution.
