Until then you can easily use command line tools. If you apt-get install lame and pacpl (perl audio converter) you can rip using pacpl - - rip all - - t mp3 destination_directory
See pacpl - l
Or use kodi to rip to aac and convert to mp3 with pacpl
Hum, it is not. Where can I check if its active/running? (I upgraded from Helix to Isengard via sudo apt-get dist-upgrade, I did not do a full clean install). Otherwise: if it’s not installed, where can I find the addon to install it?
Last week an update was shown. I installed it (took a while, seemed to be a big one) and now I have more than 2 choices for an encoder for CD ripping. Great!
