@Eternal_Pessimist Hi, can you open a separate thread, please? Thx. If it figures out to be the same issue like @BlueGTR has, we can merge the both topics, again.
@BlueGTR: To get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
