MKV with embedded DV layer playback issues after November update
Thought I’d start a separate thread here to see if this is just a me issue.
Prior to the November update, all my collection of 4K MKV files with embedded DV layer (Profile 7 MEL) would play fine as regular HDR10 video.
Since this update however, some files would play fine, however some would result in dim slideshow-video and regular audio.
The mediainfo for this problematic file is as per below:
Format                                   : Matroska
Format version                           : Version 4
File size                                : 51.7 GiB
Duration                                 : 1 h 41 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 73.2 Mb/s
Encoded date                             : UTC 2021-11-26 02:08:29
Writing application                      : mkvmerge v61.0.0 ('So') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
IMDB                                     : tt0101272
TMDB                                     : movie/2907
Video
ID in the original source medium         : 4113 (0x1011)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 68.9 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (23976/1000) FPS
Original frame rate                      : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 48.7 GiB (94%)
Language                                 : English
Default                                  : No
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1000 cd/m2
Maximum Frame-Average Light Level        : 214 cd/m2
Original source medium                   : Blu-ray
Audio
Format                                   : DTS XLL
Format/Info                              : Digital Theater Systems
Commercial name                          : DTS-HD Master Audio
Codec ID                                 : A_DTS
Bit rate mode                            : Variable
Bit rate                                 : 4 150 kb/s
Channel(s)                               : 6 channels
Channel layout                           : C L R Ls Rs LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 24 bits
Compression mode                         : Lossless
Stream size                              : 2.93 GiB (6%)
Title                                    : DTS-HD MA 5.1
Language                                 : English
Default                                  : Yes
Forced                                   : No
Logs are here: https://paste.osmc.tv/itafukocod
Any chance to have this looked at or if not, possibly downgrade to a previous release?
I believe this is an upstream issue with ffmpeg/ Kodi.
Do you have a sample we can look at?
Indeed I do, here’s a 30s sample file.
So… out of nowhere, these video files started playing normally again without any changes to anything… ¯_(ツ)_/¯
