I have a problem with play movie in the MKV format. Is not playing smoothly.
I was trying to find solution but withou success.
In the kodi.log file I see:
11:19:57 59.868172 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:57 59.875854 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
11:19:57 59.909306 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:57 59.929161 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:57 59.959415 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:57 60.028183 T:1504515056 ERROR: Previous line repeats 2 times.
11:19:57 60.028454 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
11:19:58 60.070362 T:1494504432 DEBUG: CDVDPlayerAudio::HandleSyncError rr:0.99887 error:9.300ms
11:19:58 60.071327 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:58 60.173214 T:1504515056 ERROR: Previous line repeats 2 times.
11:19:58 60.173458 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:58 60.198200 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
11:19:58 60.208908 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:58 60.304497 T:1504515056 ERROR: Previous line repeats 1 times.
11:19:58 60.307720 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:58 60.309071 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:58 60.336323 T:1504515056 ERROR: Previous line repeats 1 times.
11:19:58 60.336674 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:58 60.360905 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:58 60.390301 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:58 60.409142 T:1494504432 DEBUG: Previous line repeats 1 times.
11:19:58 60.409397 T:1494504432 ERROR: ffmpeg[591453F0]: [aac] element type mismatch 3 != 0
11:19:58 60.483406 T:1504515056 ERROR: Previous line repeats 1 times.
11:19:58 60.483669 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
11:19:58 60.492451 T:1958036016 DEBUG: ProcessMouse: trying mouse action leftclick
11:19:58 60.493305 T:1504515056 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
11:19:58 60.593777 T:1648219120 DEBUG: CDVDMsgGeneralSynchronize - global timeout
11:19:58 60.594028 T:1648219120 DEBUG: CDVDPlayer - CDVDMsg::GENERAL_SYNCHRONIZE
11:19:58 60.594151 T:1958036016 DEBUG: CDVDMsgGeneralSynchronize - global timeout
11:19:58 60.594791 T:1958036016 DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
11:19:58 60.595051 T:1958036016 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
Info about movie:
Format : Matroska
Format version : Version 4 / Version 2
File size : 443 MiB
Duration : 55mn 57s
Overall bit rate : 1 106 Kbps
Encoded date : UTC 2015-05-23 02:18:21
Writing application : mkvmerge v7.9.0 (‘Birds’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : HEVC
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 55mn 57s
Bit rate : 906 Kbps
Width : 1 920 pixels
Height : 960 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Original frame rate : 23.976 (23976/1000) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.021
Stream size : 363 MiB (82%)
Writing library : x265 1.7+2-d7b100e51e82:[Windows][GCC 4.8.2][64 bit] 16bpp
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / weightp / no-weightb / aq-mode=1 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=905 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 55mn 57s
Bit rate : 192 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Frame rate : 23.438 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : 31ms
Stream size : 76.8 MiB (17%)
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Duration : 53mn 3s
Bit rate : 6 753 bps
Count of elements : 746
Stream size : 2.56 MiB (1%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:04:59.299 : en:00:04:59.299
00:11:28.062 : en:00:11:28.062
00:20:00.908 : en:00:20:00.908
00:30:52.559 : en:00:30:52.559
00:40:10.158 : en:00:40:10.158
00:49:55.451 : en:00:49:55.451
00:53:43.554 : en:00:53:43.554
