I’m a newb and am having a good time tinkering with OSMC. My problem is that I’m getting an error message on two different displays that I plug into. Both say a variant of “Mode not supported”. The message comes from the display and/or TV, it is not an OSMC message. At one point, I searched and found a thread on this forum that mentioned this:
“Followed the suggestion, and redid sudo apt-get update && sudo apt-get dist-upgrade && sudo reboot. Picture came back. Thanks!”
That caused something to update with the dist-upgrade part and then everything worked for a reboot or two. I can get SSH access, but I’m at a loss as to what to try next. I have also tried a new HDMI cable, but that didn’t help.
Ok, here goes.
The problem: I recently bought a Raspberry Pi 3 Model B. I used the Noobs tool to load up the OS for OSMC. It worked fine then. As part of the setup tool, I updated OSMC and that is when the issue first appeared. It may not be related to those steps, but I keep getting “mode not supported” from any display I plug into the HDMI. I have tried new power supplies and different HDMI cables.
What I was doing: After a reboot, the issue occured. Once, I was able to run the commands mentioned in my post above, but it only solved the problem temporarily. I’m not back to “mode not supported”
Can I replicate the issue: Yup. I’m stuck and cannot get a display. I can SSH in though.
Device: Raspberry Pi 3 Model B
Peripherals: A USB wireless keyboard and the HDMI monitor/tv. Both HDMI devices have the same ‘mode not supported’ message.
Past experiences: I’ve only just begun with OSMC and this issue has popped up twice. I cannot figure out what causes the problem to go away. I can say that once when I booted, I did not get the ‘mode not supported’ but got a display washed out in green tones. It was nearly unusable. When I tried to change display resolutions, I got the ‘mode not supported’ message.
Logs:
I have generated these log files via SSH, as I cannot get a reliable display. In this example, I am seeing a green mess of flickering over my Samsung TV:
https://paste.osmc.tv/epexucomed
Your display EDID is not being read. It seems the Pi is trying to send 1080p 60Hz - surprising your TV doesn’t support that if it’s fairly new (at least ‘HD ready’). You could try putting:
hdmi_group=1
hdmi_mode=20
in /boot/config.txt. See Raspberry Pi Documentation - Configuration for other options.
If you only plan to run OSMC then please reinstall with OSMC Pi2/3, since
these settings make no sense on a Pi3
NOOBS Auto-generated Settings:
arm_freq=850
core_freq=375
So, install from Download - OSMC - if it still doesn’t work then RMA the Pi3 since you have tested on two separate TVs.
Regards
/L
I ended up RMA’ing the Pi. The new one has no problems. Thanks for the help everyone.
