im using the xbox one remote IR remote with osmc.
The standard buttons working totally fine. But i want to change some buttons, for example, i press the back button and the section “movies” appears.
Where do i have to change it?
thx
thx
no ideas ? no possibility for chaning the mapping ?
You can just edit the LIRC config file.
you mean the /usr/share/kodi/system/Lircmap.xml ?
i dont have the feeling that this is the right one
no idea ?
Just edit the LIRC config
