Moonlight within OSMC?
So I’m using the latest version of OSMC on my raspberry pi 3. I plan to build a gaming machine with an Nvidia graphics card, and I noticed an open source program called Moonlight that allows you to game stream to a Pi running Raspbian.
My question is: would I be able to run Moonlight within OSMC or should I have a separate SD with only Moonlight installed?
And a follow up: If I can run it within OSMC can I make it appear in the ‘Programs’ section for easy selection
Thank you very mcuh!
