More April Release Blues
Welp, the April release didn’t go well for my RP2b. I was using Mimic skin which no longer works, the Harmony IR remote is hit-or-miss, and I’ve had multiple sad-faces.
I know just enough technical steps to download and configure, so rather than troubleshoot I’d rather just revert to the prior config – if I run into trouble using the OSMC restore utility using a backup made with the OSMC utility, can I just copy the image from a RP3 that had an identical config?
The WAF really wants a common UI between the RPs and PC-based Kodi installations.
Thanks!
DOH! Nevermind, just found this re: RP3-to-RP1 - Restore full backup from RPI 3 to RPI 1.
