Hi.
I have an network nas drive with called Homeserver
I want to mount the folder on osmc.
i have tried to do this
sudo mount -a //homeserver/Volume_1 /mnt/Volume_1 cifs uid=8888,gid=8888,iocharset=utf8,rw,auto,user 0 0
where is my mistake?
Thank’s in advance
You can’t mount samba shares like that unless you have smbclient installed, and they will only stay mounted until you reboot. It is better to mount them in /etc/fstab (googling mount smb share in fstab will lead you to many howtos).
Or you can just go to File Manager in OSMC click on Add Source and browse to it
You can do it via /etc/fstab
First create a mount point:
mkdir –p /mnt/share
Then create a smb credential on you osmc home
nano /home/osmc/.smbcredentials
With these entries:
username=username
password=password
domain=domain
Finally in /etc/fstab
//server/share /mnt/share cifs credentials=/home/osmc/.smbcredentials,x-systemd.automount,noauto,iocharset=utf8,sec=ntlm 0 0
by
den
