So I have a hard drive attached to my router and I want to mount it to my raspberry pi 3+. I’m able to set it as a shared drive and view all the files there, but I want to be able to use it as a plex server as the plex client is much better than the stock video file viewer.
The shared drive is shared through smb://TM-AC1900/Memory_Alpha. I’m not sure if I’m able to use that as part of the fstab file, or what ip address I’m even supposed to use. In addition, if someone could help me configure the entire fstab file, that would be greatly appreciated as my coding skills are greatly limited.
The IP address you need to use is your routers ip address.
I’m guessing your router is a T-mobile AC1900, is this correct?
If so its a locked down asus router, does it have section called something like: “USB Application - Network Place (Samba) Share / Cloud Disk”? Have you enabled guest login and what is “Samba protocol version” set to?
Since then I have reset my os and am starting from scratch. However, the commands in the link above no longer work. The name has changed from Memory_Alpha to Memory_Beta as the first name changed to have a (1) at the end and through troubleshooting decided to just change the name. Any help in getting this to work again would be much appreciated.
Thanks!
Hello,
Sorry for the delay, school has just been super busy. When I changed the domain to what was put, I now get
mount error(16): domain or resource busy
