I installed OSMC on my Raspberry Pi. It shows the mouse icon as a strange line. I can’t figure out how to fix it. I see it in different skins so it’s not the one that i’m using that’s causing the problem.
Here is a screenshot of my issue.
It’s not a widespread problem as you are the only person reporting the issue. It’s apparently something local to your installation. There is nothing OSMC can do to fix. Either try rebooting a few times or re-install.
I just received an update today. I usually check for updates every 2 days so I am definitely up to date. My log is here: http://paste.osmc.io/jetasuhina
It fixed it’s self after updating, although it appears to be broken again (as i’m typing).
That is correct. I can have it generate a new log if you want. It’s currently running on an Apple iPhone PSU. I assume that is “Good”. Yes I do have a wifi adapter.
