Movie stops after 4-5 seconds , after December update
Hi, I have the problem , that after the Dezember update ( I had one sad face, right after the update, but never since) all my movies stop after 4 or 5 seconds , like I would stop the movie .This happens also with movies I watched without problems before the update. I put the log files here:
https://paste.osmc.tv/eduxenaven
what could I do ?
I think the movie Debug starts at :
20:29:42.310 T:4074992208 DEBUG: OnPlayMedia smb://192.168.2.108…
Andi
You play a video from a NAS, is it a Synology?
That’s right DSM 6.1 with smb
I just updated today also and have the same problem, i also have synology DS1817+ and did the latest update. and still have the problem
I just tried a USB stick on the Vero 4K directly , works fine …
This sounds quite similiar. Perhaps both threads should be merged.
Have you tried to set the max. smb version setting to smb3 on the Syno?
On the Syno: Control Panel → File Services → SMB → Advanced Settings
ok i have set the max.smb to smb3 seem to be working ok now. will let you know if i still encouter problems later. Thank you very much
Samen problem here with a Synology NAS.
Thank You, JimKnopf
That was it in my case : control panel > File Services > SMB > Advanced Settings : Maximum SMB protocol : SMB3
after a restart of both Sinology and Vero 4K it works again !!
See 4 posts above.
Great thanks, I had the same problem but this fixed it.
Thanks again
Jup that did the trick.
Thanks :slight_smile:
Just ran the December update, may have the same issue. Log is here: https://paste.osmc.tv/gehuyezajo
Tried to play an episode of Grimm, stopped after a few seconds.
I have an Unraid server,and apparently can raise the SMB protocol. But if I do that, my non-OSMC Kodi clients won’t connect as they’re stuck on SMB1 until v18.
So is there a way to let OSMC connect as SMB1 for now? I remember changing a file when I first received the Vero to let it connect as SMB1, but can’t remember what I did.
@plum23 OSMC GUI: Settings -> Services -> SMB Client
Thanks so much. I had no idea that was in the settings menu.
