I run the movie baggage claim, and within 1 minute it starts to lag, if I log at debug, 1 cpu core is 100% and memory stagnates at about 622/7xx MB so I think this might be the issue, I just dont know why it goes so high?
Here is my log, it was too big to upload with MyOSMC https://dl.dropboxusercontent.com/u/19153690/uploadlog.txt
Is it possible to print out what is using memory on hte system at a given instant? Also is it possible to list all addons intalled? because they seem to be in different categories
I have a RPi3
You seem to have the Pi1 build installed.
I just used Download - OSMC and chose the windows installer, shoudlnt that work? btw where do you see that. And if thats the case, isnt it wierd that wireless works?
This would be a clue:
Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
21:48:32 8.948867 T:1956774832 NOTICE: ARM Features: Neon disabled
If you really have a pi3 you have to select it in the installer.
I thought I did that, is there a way to make a copy of my current install of the SD card and then try another install?
Hmmm. Probably I am wrong here…
Pi 1 should be armv6.
In this case… can you give us info about the file? What codec etc.
Use mediainfo.
