Movies submenu not accessible without Recent Movies populated
In the OSMC skin, if the Movies widget - Recent movies is not populated, it is not possible to go to the Movies submenu (Genre, Year etc). Seems you must go right first to the first recent movie and then down to the submenu. Tested by marking one movie as “not shown” in order to populate recent movies, and then it worked. This must clearly be a bug!
actually, im sure this is consistent with confluence.
i know with the default kodi skin confluence, you can edit the home.xml and change the “movies” section to remove something like “has.content” or something similar, then the movies menu will appear always, even if no library is setup.
D.
@Damo - The Movies submenu is always visible. The problem is that you can’t get to it using the remote if there are no “Recent movies”! Btw the header “Recent movies” is misleading since it is in fact unwatched movies displayed in the widget…
