They are simply not shown anymore in the GUI (i can see them using my PC, so NAS is fine), after they have been played once. I dont mean from the library (i dont use library to find movies), but simply when you browse your files in osmc. The only way to get them back is to copy them again ^^
What is this? Hasnt been like this before and i cant find a setting to turn this off.
Thanks fpr your help,
Markus
Check the filters, it is probably on “unseen” put it to “all videos”.
ooOO yes thanks…the very parent folder hat the filer activated. ![]()
Thx
