Hi there,
I bought hifiberry digi+ clone card (pifi digi+) and i have problem with install it. After 2 days of fighting with it, and digging i found topic Hifiberry digi+ not working with January update and info that my system is hosed
(as Sam called it) - i using āapt-get upgradeā⦠I check on new fresh system that my card works perfect. So now i want install new fresh system, and move my kodi setting ( i have a lot of plugins and repo installed) to new system.
But how i should it do? Just normal copy of ~/.kodi folder to new place? (using linux laptop)? Or only some specifict folders? Maybe use rsync? Only .kodi folder will be enough? I only want to save my kodi config, no whole system.
Thanks for help.
