I am finding that some MP4 files stutter when playing and others play fine, is there anything I can do in the settings about this? A file that works is a DVD I ripped using Handbrake and one that doesnt work is a home movie I created using MS Movie Maker.
Raspberry Pi V1 with only 256MB
Files live on a Dlink NAS accessed using an NFS share
I use homeplugs to connect from the Pi in the lounge to the Router in the study, the Dlink NAS is connected via 10/100 ethernet to the router
I read another post on here about mediainfo and here is details of a file that works:
General
Complete name : Z:\Films\DVD_RIP.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.19 GiB
Duration : 2h 11mn
Overall bit rate : 1 289 Kbps
Encoded date : UTC 2015-10-03 12:16:14
Tagged date : UTC 2015-10-03 13:42:43
Writing application : HandBrake 0.9.6 2012022800
Video
Format : AVC
Format profile : Main@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 11mn
Bit rate : 1 125 Kbps
Width : 720 pixels
Height : 428 pixels
Display aspect ratio : 2.40:1
Original display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.146
Stream size : 1.04 GiB (87%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2015-10-03 12:16:15
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 11mn
Bit rate mode : Variable
Bit rate : 160 Kbps
Maximum bit rate : 236 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 151 MiB (12%)
Title : Stereo
Language : English
Menu
Codec ID : text
Duration : 2h 11mn
00:00:00.000 : Chapter 1
00:03:48.160 : Chapter 2
00:09:32.720 : Chapter 3
00:14:29.480 : Chapter 4
00:23:21.600 : Chapter 5
00:30:34.200 : Chapter 6
00:38:15.520 : Chapter 7
00:42:59.480 : Chapter 8
00:48:15.680 : Chapter 9
00:58:10.960 : Chapter 10
01:01:47.000 : Chapter 11
01:09:27.520 : Chapter 12
01:17:16.480 : Chapter 13
01:27:03.760 : Chapter 14
01:31:57.560 : Chapter 15
01:38:52.440 : Chapter 16
01:46:46.560 : Chapter 17
01:51:11.840 : Chapter 18
01:58:41.280 : Chapter 19
02:03:39.800 : Chapter 20
Bit rate mode : VBR
And here is a file that doesnt work:
General
Complete name : Z:\Family_Videos\ACWS Portsmouth 2015.mp4
Format : MPEG-4
Codec ID : mp42
File size : 310 MiB
Duration : 4mn 34s
Overall bit rate : 9 468 Kbps
Video
Format : AVC
Format profile : Baseline@L4
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Duration : 4mn 34s
Source duration : 4mn 34s
Bit rate : 9 272 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.149
Stream size : 304 MiB (98%)
Source stream size : 304 MiB (98%)
mdhd_Duration : 274875
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4mn 34s
Bit rate mode : Constant
Bit rate : 192 Kbps
Stream size : 6.32 MiB (2%)
mdhd_Duration : 274816
Can anyone help?
Simon
