So I have come home and rebooted with both TV’s and have the following details.
Looks like the mode it is detecting is not compatible with the other and vice versa.
So, I understand if I FORCE it to Mode 5 (Compatible with both) all should be ok?
Pioneer
root@osmc:/boot# /opt/vc/bin/tvservice -s
state 0x12000a [HDMI CEA (20) RGB lim 16:9], 1920x1080 @ 50.00Hz, interlaced
root@osmc:/boot# /opt/vc/bin/tvservice -m CEA
Group CEA has 13 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
(prefer) mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
mode 21: 720x576 @ 50Hz 4:3, clock:27MHz x2 interlaced
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
Other TV
root@osmc:~# /opt/vc/bin/tvservice -s
state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
root@osmc:~# /opt/vc/bin/tvservice -m CEA
Group CEA has 14 modes:
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
(native) mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced 3D:SbS-HH
(prefer) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive 3D:SbS-HH
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced 3D:SbS-HH
mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive 3D:SbS-HH
mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 33: 1920x1080 @ 25Hz 16:9, clock:74MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive 3D:SbS-HH
