grab-logs -A and then provide the URL
Before that if you are overclocking the RPi1 then disable that to check if it solves your problems.
Could you explain how “I updated” worked? Assuming that you have updated OSMC and that that pulled in a new version of Kodi. AS your update cycle is not clear could yo say if it was the october or november update or even an earlier.
Also as you had freeze problems earlier I really suggest that you check your SD card and power supply
Guys, no need to be defensive, OSMC is great so no need to attack users just because they complain on issues.
No one said “its all broken” and if you took 2 sec to read my initial post you can see I offered full logs and happy to help with QA
I went through the logs myself and found the culprit in the form of a misbehaving add-on who failed to parse URLs (bad regexp) but kept trying to connect to various sites.
My (overclocked) RPI could not deal with this overhead so everything was lagging including MyOSMC.
I have fixed the addon and will see if there are any issues, If there are I will post my logs.
Are you happy with the kodi.log or prefer the grab-logs data?
It’s not about being defensive. It’s that your statement makes very little sense when you state 15.2 broke things for you after being the current release version for 3+ months.
Its makes a lot if sense as it describes the issue and perhaps a cause and as someone who support several software related products 3+ months is nothing.
I understand you are supporting a freeware but still your attitute should be more positive and helpful.
If you lack the patience to help you should focus on development instead. The OSMC/KODI community and your devs are very helpful anyway.
