Hello,
On my music library, if i navigate artists with “no details (artist informations)” on the GUI, the time to go to other artist is normal (the remote respond well). When i had details ('desactiver les infos to off) then it’s very long and i can’t navigate normally.
Is it a way to correct it ?
KR
I don’t fully understand the question
When i navigate in my music librairie with OSMC there is no latency if i navigate in artist librairy with only the name of artist (its a interface parameter).
When i change parameter in interface to add artist information, there is a big latency when i navigate.
Is it more clear ?
Thks for you advice
I suspect we would need some logs and to know which skin you are using
