Hi…on Friday, 3 days ago, these were working fine. On Saturday, not working…don’t know if there was any update or not.
The playlist file is from the iinet freezone :- http://freezone.iinet.net.au/freezone-radio-playlist.pls
The error log is here :- http://paste.ubuntu.com/23367353/
Jarvis on Pi 3.
Any ideas?
Thanks,
bt
Most likely the Playlist is outdated. Try to open parts of it in your browser and you will see.
http://radio1.internode.on.net:8000/171
Worked fine? This one has been around for years, so I don’t think it is likely to change?
Debug log is needed. The log you uploaded does not have debugging.
Ok, thanks. I will give that a go.
I turned debug on
http://paste.ubuntu.com/23376847/
The http://freezone.iinet.net.au/#/radio ABC Grandstand link I tried to play is /171 here but in the log is showing /292 so that is strange?
http://radio1.internode.net:8000/171
I tried making a .STRM file with just the ABC Grandstand stream in it, to test again
log here
http://paste.ubuntu.com/23376930/
You have a lot of addons installed, did you install any new ones just before this started failing? Or did any update?
I didn’t install any others Friday or later, no. I will look and see if any updated.
