Please help me.
One of the main reasons I got the Vero 4K is to display my photos on my 4k TV Screen (the image viewer of tv is terrible)
But the photo are displayed in low resolution. I can can compare with the TV viewer (it is terrible to use but, at least, it does 4k display of the images)
The video resolution of the Vero4k is set to 4096x2160p
I have the last update
Is there a specific setup to do to use the UHD on the image viewer?
Well, first I can see there are a lot of details lost. Which is a sign of lower resolution
But I tryed specificaly the images test there :
And with my main computer or the TV viewer, I can read the third sentence and I can see the small dots in the background
With the Vero4K I canât read the third line and the background is gray.
So that means it is not displaying the image at 3840x2160 as it should.
Thereâs a year-old thread on the Kodi forum here where this issue is raised. Assuming the points still apply, it seems that the GUI interface runs at 1080p for performance reasons, since running at higher resolutions would produce a more âclunkyâ, less fluid interface on a Vero 4K (or Raspberry Pi, for that matter), hardware acceleration only being available to video formats such as H264 and HEVC. Photos, not being video, are therefore displayed at the GUIâs resolution. That, at least, is my interpretation of whatâs on the thread.
The issue is also that Kodiâs scaler isnât very good; so itâs better to run the GUI at 1080p and have the TV do the scaling (which almost always looks better).
I posted in the other thread (which was one year old), nobody replyed so far.
On what I read here and in the other thread, it seems that it is normal to not be able to display a 4K photos
What has to be âhardware acceleratedâ to display still images?
Am I the only one pointing that it is a problem or a bug?
I bought a 4K device and I canât display photo in that resolution, Iâm really surprised and disappointed.
The device is primarily intended for playing back 4K content.
We recommend the GUI runs at 1080p. The quality will likely look better than if you
run the device at 4K. OSMC is based on Kodi, so the usual limitations of that platform apply.
I can add support for running the GUI at native 4K resolution.
I havenât done this yet as youâre the first / only user to request
this. Be aware that the GUI performance would be quite degraded
however, and we wouldnât recommend this.
OK â Iâll see what can be done. Itâs a little lower on the list of priorities because there havenât been many requests for this, but it can now be considered on the list.
I am currently running osmc on a rpi2 and am generally pleased with its performance. I am thinking of replacing my panasonic plasma with a 4k display and upgrading to a vero 4k. My main activities are playing music and showing photos and home videos. I have read in one of the threads that the vero will only show my photos at 1080 max. Its clear from the forum that most users stream video and that photos are probably lower on the developers todo list but I wondered if there were any plans to introduce 4k photos.
