Thanks Sam and darwindesign, I read something but can’t remember the answer, Their isn’t an osmc load version that V uses to load onto a Vero4K+ as it not backwards compatible-Correct. Just thinking if I could load it just to see that quality of the picture viewer part only? I notice the basic Sony android TV media player pictures are also brighter and better colour and contrast as well as 4K but I have no file protection to give my clients a usb stick.
See my new topic post about the V being able to help sort this out by pointing at a web page .
Not sure which category to use so started with V help and support. Shift it as needed or do i have to do that. Sorry a newby in online things
4K+ won’t have the resources to handle a proper 4K framebuffer.
We’ve listened, and as promised @tanio99 has integrated this.
Unfortunately the Vero 4K + can’t perform well with a 4K GUI, but Vero V can handle this comfortably. We still don’t recommend a 4K UI set as default yet due to some issues with Kodi’s video whitelisting configuration, but you should now be able to see photos and the UI at a true 4K resolution.
We would appreciate it if you could test this and provide feedback before we potentially release this as an update to other users. To test this update:
- Login via the command line
- Run the following command to add the staging repository:
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list
after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list
