Could anyone please help me? I’m not an expert in this sort of thing, the picture plays fine but the font and background of the menu interface, at times appears to have lines through it, I hope my picture helps. Could it be a HDMI issue? Appreciate any help!
Your resolution is probably set to an interlaced mode.
If you upload some logs we can check.
Make sure the UI is set to 1080p and not 1080i
Ah, that fixed it, thanks! It was set to 1080i, so will the quality still be as good for UHD films? Thanks again!
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
