hi All!
I’m getting quite many times a My OSMC error during launch, i’m using an rpi2 and the latest OSMC. As the My OSMC menu is not starting in cases like this to be able to upload the log properly, i just went to the kodi.log and here is what i see there:
12:33:10 41.252838 T:1727874032 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.SyntaxError'> Error Contents: ("Non-ASCII character '\\xa0' in file /usr/lib/python2.7/dist-packages/urllib3/util/__init__.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details", ('/usr/lib/python2.7/dist-packages/urllib3/util/__init__.py', 1, 0, None)) Traceback (most recent call last): File "/usr/share/kodi/addons/service.osmc.settings/service.py", line 26, in <module> import resources.lib.osmc_main as m File "/usr/share/kodi/addons/service.osmc.settings/resources/lib/osmc_main.py", line 52, in <module> import osmc_walkthru File "/usr/share/kodi/addons/service.osmc.settings/resources/lib/osmc_walkthru.py", line 11, in <module> import requests File "/usr/lib/python2.7/dist-packages/requests/__init__.py", line 55, in <module> import urllib3 File "/usr/lib/python2.7/dist-packages/urllib3/__init__.py", line 10, in <module> from .connectionpool import ( File "/usr/lib/python2.7/dist-packages/urllib3/connectionpool.py", line 31, in <module> from .connection import ( File "/usr/lib/python2.7/dist-packages/urllib3/connection.py", line 44, in <module> from .util.ssl_ import ( SyntaxError: ("Non-ASCII character '\\xa0' in file /usr/lib/python2.7/dist-packages/urllib3/util/__init__.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details", ('/usr/lib/python2.7/dist-packages/urllib3/util/__init__.py', 1, 0, None)) -->End of Python script error report<--
Is there any fix for this?
cheers
