I am unable to launch My OSMC. I get an error message to see log. Also, any skin interface changes do not take affect unless I reboot (used to be immediate with a confirmation prompt); not sure if its related, but mentioned in case.
Please upload full logs so that we can see the MyOSMC package version
Try searching for updates via MyOSMC
Sorry you need to login via SSH and run
sudo apt-get update
sudo apt-get dist-upgrade
That worked!
Thank you for the help, and very quick response
