I seem to have an issue whereby if I go into My OSMC -> Pi Config I get “No categories available”.
I get the same message for My OSMC -> Updates and My OSMC -> Log Uploader.
I pulled this over to its own topic as it wasn’t particularly related to the previous thread. Can you post a debug log please.
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Thanks for the reply, and the logging instructions.
This isn’t an issue after all. It all works now.
I think it might have been caused by me having previously switched the settings-level to basic (because if you do that you get the “No categories available” message.
So, my fault
