I’m also getting the “My OSMC Error” and an “Updates Error” after the November update. The update was through OSMC’s normal built-in update manager. I’ve manually cut/paste the log into paste.osmc.tv’s editor from my laptop using ssh, since My OSMC isn’t functioning. So, hopefully this is the right URL for the log: http://paste.osmc.tv/iwupasefak.vhdl
Also, mine is on a Raspberry Pi 3B+, not a Vero. I apologize if I commented in the wrong place. I just saw someone had the same problem as me, and jumped into it without thinking about what part of the forum it was in.
You need to upload full logs.
grab-logs -A via SSH
Here they are: https://paste.osmc.tv/valohizoze
You can update again: sudo apt-get update && sudo apt-get dist-upgrade. This will solve your problem.
YES! now it started installing and finished succesfully
That worked! Thank you!
