My OSMC radial menu
Hi guys, I love the original skin, but is it possible to have My OSMC menu which is vertical or horizontal, not radial?
I feel that that change would make it easier to navigate.
It would be nice if it would change appearance with the skin used!
When did you last update?
My installations have been with MyOSMC menu horizontal for a while now
Derek
I’ve got 2015.08-1 and it’s radial.
Have I missed some setting to make it horizontal?
This might be a question of detail:
For me, if I click on MyOSMC, I get the radial display
but if I merely move the cursor over MyOSMC, then I get a horizontal set of selectable icons
Derek
I’ve tried it under Confluence, MyOSMC is in the submenu of System (Home screen)
When I click on it it’s radial.
I was hoping there was a way for it to be vertical or horizontal (maybe an option so users can choose?).
This is only on OSMC skin
I figured as much, it would be very useful if it could changed to horizontal or vertical.
I agree. I don’t use the OSMC skin and I find the radial menu of MyOSMC to be a triumph of form over function and not at all intuitive to use with a remote.
