Hello,
My remote don’t work anymore. The battery is ok (3V). The blue light seems to work. Strangely, sometimes, without doing anything, but very rarely, it works.
I had to use a mouse attached to the vero 4K+.
Any idea ?
Lucas
Hello,
Any idea ?
Lucas
Have your tried repairing the remote? (by holding Home and OK)
Thanks Tom.
Hello,
I didn’t know that. I just did it, but nothing happened at the screen.
I think the blue light on the remote should flash to indicate the pair was successful. Please post some logs.
Thanks Tom.
Are you sure about that. A “dead” CR2032 is only about 0.2 volts below that so a tester that isn’t providing any load might not quite pick up if the battery is good or not. Have you tried just replacing the battery anyway.
Try another, new, battery.
Hello, I have a debug log, but it is too large to post; how do I do ?
Reboot twice before creating logs and they won’t be of an excessive size.
And before anyone starts looking into logs: Have you inserted a new CR2032 batterie as Sam suggested? They only cost around 0.60 EUR if you buy them in a blister pack of 10.
Hello,
I put a new battery , whose voltage is slightly above 3V.
I had the same result, nothing happens, although there is a blue light at each press.
reproduce the issue
Hello,
this is the url of the debug :
https://paste.osmc.tv/osoyapuqed
The dongle may be defective. You should contact support@osmc.tv with your order number and reference to this post so we can resolve this for you.
