Hello. I don’t understand very much of this, but when I go to My OSMC - Updates - Manual Update, it scans for new update, but tells me there aren’t any new updates.
I also have active automatic updates, but they never worked.Thanks for the help
I have the same situation on both my veros. My raspberrys have updated. I think that those both hardware platforms have different update levels. I do not think that there is anything wrong
November 2020 2020.11-1 is the current version. It isn’t stuck there. There’s nothing newer to get.
That’s correct. November 2020 is the latest.
It’s not possible for your Pi to show a newer version.
There are newer test builds available, but they will still show this version in My OSMC
Thanks for the help. Justto clarify I don´t have a PI. I have a Vero 4k. Thanks again
You’re on the latest stable version. Stay tuned for a newer stable release.
I’m definitely tuned into this !
Any idea when we can expect a new stable release, it must be getting close now Sam ?
A little bit less close, with every question =) I can just refer to “not before 19.1”, and now 19.1 is released. I know there won’t be a release till Sam thinks it’s mature enough for all his users. And there is a lot of work behind the scenes.
