When i install a custom Build for Kodi, the myOsmc program addon disappears.
Maybe it is possible to define this as an must have addon in kodi.
I mean that the system should check for its existence and if it isn’t present it should be installed again)
Would be great.
thanks
Rene
It should be visible under Programs, but it won’t be on the home menu of a custom skin.
We offer no support for community builds for obvious reasons. We have no way of mandating to the developers of such builds that MyOSMC must be included. You are on your own in this respect. If it has not actually been removed, it will always be available under Program addons. You may just have to configure the skin to provide the addon on the menu.
