MyOSMC is missing in main menu
Hi there,
See topic.
I can only get to it via Apps, left on the remote, Programm addons, MyOSMC.
I am on the osmc skin.
Sam asked me to provide logs - which ones would you need? Is a reboot needed to fill the logs?
Note beside: there is also a search menu item which does nothing… Not sure if that’s supposed to be?
OSMC Skin is configurable quite easy in Settings, have you looked there?
Well @sam_nazarko asked for logs and a photo of what you see on the screen.
For the logs details follow @ooZee info but please also upload picture.
Just wanted to make sure if you would need a full log for this “problem”.
What photo would you want? Of the main menu?
Yes, main screen
OK, here there are…
Please have a look at Settings/Interface/Skin/-Configure skin…/Home/Customize home menu. There you’ll find the option Restore original home menu items. This option should offer you My OSMC as a restorable item…
Hope that helps. :+1:t2:
That worked, thanks!
Good to hear :slightly_smiling_face:
