I have upgraded to Raspberry Pi2 so decided to give OSMC a go. So Far I love it. I run an ubuntu box with Kodi under my living room tv and use that as the master. I have the Pi behind a TV in the bedroom which connects to the master’s MySQL database.
The pi doenst seem to connect to the library and I am seeing errors in the log file saying it was unable to connect to the MySQL server. When i run a restart “sudo systemctl restart mediacenter”, Kodi restarts and connects to the database server fine. I think it may be to do with it trying to connect to the database before the WiFi has initialized. Is there a workaround for this?
I have seen some other posts editing /etc/init/xbmc.conf so it will not boot kodi until wifi connection is established, but this no longer exists in OSMC (I assume due to the way you have customised the OS).
I have 2 profiles on my setup – 1 setup with a local storage and the other setup with a remote MySQL database and NFS mounts. I set Kodi to boot to the login screen, and as long as the network connection (and VPN link in my case) comes up before I log into the profile that uses the MySQL db, there isn’t a problem. Maybe you can use the login screen as a workaround for the time being.
this would be great.
but please add also an option to check if ** local ** mysql-db is already running.
this is also a problem on bootup which needs to handle.
thx!
