I’ve recently purchase a second Vero, this time a Plus. One of its uses is to act as a MythTV front end. It generally works perfectly and is noticeably faster than the original Vero which serves our second TV.
However, at the same time every night, the connection between the Myth backend and the Vero resets. I haven’t noticed this behaviour before. The native front end we previously used and the original Vero never did this. It’s an annoyance rather than a major problem.
I acknowledge that the problem may reside in the Kodi MythTV addon. However, any advice regarding obvious things to check would help.
Thanks for any advice you can give.
If you provide some logs surely will make it easier to give advice.
Finally got some logs.
https://paste.osmc.tv/cejevofose
Happens the same time every night, at around 20.10
If we’re using the mythtv plugin, it will disconnect.
Would appreciate advice of where to go from here.
Thanks.
Checking the logs for 20:10 it seems to be triggered by a EPG referesh. Maybe check your EPG configuration.
2021-06-03 20:10:31.793 T:3528450272 DEBUG: Thread EPGUpdater 3528450272 terminating
2021-06-03 20:10:31.795 T:4064545984 DEBUG: CDirectoryProvider[pvr://channels/tv/*/]: refreshing..
2021-06-03 20:10:31.796 T:3536842976 DEBUG: Thread PVRGUIInfo 3536842976 terminating
2021-06-03 20:10:31.797 T:4064545984 DEBUG: CDirectoryProvider[addons://sources/game/]: refreshing..
2021-06-03 20:10:31.797 T:4064545984 DEBUG: CDirectoryProvider[pvr://channels/radio/*/]: refreshing..
2021-06-03 20:10:31.832 T:3929010400 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1001&Width=300
2021-06-03 20:10:31.832 T:3536842976 DEBUG: Thread JobWorker start, auto delete: true
2021-06-03 20:10:31.833 T:3920617696 DEBUG: CTextureCache::CacheImage - Return NULL texture because cache is not ready
2021-06-03 20:10:31.837 T:3929010400 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1012&Width=300
2021-06-03 20:10:31.840 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1775&Width=300
2021-06-03 20:10:31.845 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1012&Width=300
2021-06-03 20:10:31.850 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1775&Width=300
2021-06-03 20:10:31.856 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1022&Width=300
2021-06-03 20:10:31.860 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1023&Width=300
2021-06-03 20:10:31.866 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1020&Width=300
2021-06-03 20:10:31.871 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1774&Width=300
2021-06-03 20:10:31.876 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1070&Width=300
2021-06-03 20:10:31.882 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1072&Width=300
2021-06-03 20:10:31.886 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1074&Width=300
2021-06-03 20:10:31.891 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1090&Width=300
2021-06-03 20:10:31.896 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1099&Width=300
2021-06-03 20:10:31.901 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1094&Width=300
2021-06-03 20:10:31.906 T:3920617696 DEBUG: GetImageHash - unable to stat url http://192.168.1.203:6544/Guide/GetChannelIcon?ChanId=1773&Width=300
2021-06-03 20:10:31.908 T:3566510304 DEBUG: Thread PVRManager 3566510304 terminating
2021-06-03 20:10:31.912 T:3953856736 NOTICE: PVR Manager: Stopped
2021-06-03 20:10:31.951 T:4064545984 DEBUG: CDirectoryProvider[pvr://channels/tv/*/]: refreshing..
2021-06-03 20:10:31.953 T:4064545984 DEBUG: CDirectoryProvider[pvr://channels/radio/*/]: refreshing..
2021-06-03 20:10:32.582 T:3953856736 NOTICE: AddOnLog: MythTV PVR Client: Addon destroyed.
2021-06-03 20:10:32.582 T:3953856736 DEBUG: SECTION:UnloadDll(/usr/lib/kodi/addons/pvr.mythtv/pvr.mythtv.so.5.10.19)
2021-06-03 20:10:32.582 T:3953856736 INFO: ADDON: Dll Destroyed - MythTV PVR Client
2021-06-03 20:10:32.588 T:3953856736 DEBUG: ADDON: Dll Initializing - MythTV PVR Client
