Mythtv goes blank after a few seconds
I’ve upgraded to the latest November release today. Everything seems ok except for mythtv playback. I use the pvr.mythtv plugin and it’s been flawless until now.
When selecting a recording to play, you will see normal playback for a few seconds. Then the display goes blank. Sound continues. Note the display is truely blank and even pressing the ok button does not show the usual playback menu. It is clearly working as a second press of ok will pause playback and pressin again resumes. However, during all of this the display is entirely blank. As soon as I press Stop, the playback ends and the display returns.
Suggest to upload debug logs (see second point below)
Can try to disable Adjust Refresh rate (see first point) while I doubt that helps
many thanks for replying promptly. Changing the refresh settings did not help.
Upload is at
https://paste.osmc.tv/oqucuwomuq
Maybe I was clear on that point, I meant set it to off currently you have it on Always.
Did you try to play a MythTV Recording/Channel in that log? I didn’t see that.
Hi fzinken,
sorry, I had misunderstood your suggestion. WIth refresh set to off, playback does work.
With it set to always I get he symptoms I’ve previously described. I’ve created a new log
https://paste.osmc.tv/fupiqahida
I did tail -f the kodi.log and could see activity when I attempted to play a recording. Note that this time I enabled PVR specific logging. Not sure if that was the right thing to do or not.
Are all recordings affected?
Is Live TV affected?
Can you produce a sample recording so we can see if we can reproduce the problem?
Many thanks
Hi Sam,
Yes, live tv is also affected th same way. I’ve produced a recording that’s just a minute long. Let me know how to get this file to you. It’s 51Mb.
This isn’t forgotten. I’m hoping to restore our video sample uploader shortly.
